Olivier POHU
Help about LPC1549
Discussion created by Olivier POHU on Jun 26, 2017
Latest reply on Oct 9, 2017 by Kerry Zhou
Hi , I work on LPC1549 and Mcuxpresso 10.0
I want debug or run my program with PEMicro Multilink Universal..
 I suppose  Mcuxpresso make the Two... but that dont' fonction.
--When my config is : ARM-none-eabi-gdb.exe
                      Flash  1x32x64K
                      file: Main.axf
The response is : "The current language do not match this frame"
                                  Flash  1x32x64K
                               file: Main.hex
The reponse is : " Monitor selectcore 0
                   No symbole table is loaded :" Use the file command"
                   Continu
                   Continuing
But that don't start
Have you a documentation who explain the  flash mcuxpresso and PE micro  or a documentation who explain
the debug config ?
Thank of your reponse
