Hi, could you kindly recommend the micro controller series which have been used for vehicle to Grid (V2G) Application.
suriyaprakasamc
could you kindly recommend the specific micro controller series which have been used for vehicle to Grid (V2G) Application.
Suriyaprakasam C
suriyaprakasamc
Hi Jing,
We are Looking for micro controller series which is already used in  Electric Vehicle communication controller (EVCC) for DC level 2 charger application.
Please, let me know if any other clarifications.
Thanks & Regards,
Suriyaprakasam C
suriyaprakasamc
Hi Jing,
Please, consider below preliminary specifications for selection of controller also indicate the availability of evaluation board.
Core Type : Dual Core
Flash Memory : 2-4MB
Operating Frequency : 150 -200MHz
Functional Safety – ISO26262(ASILD(or) B)
CAN – 3 Channels
SPI – 3 Channels
UART – 3 Channels
Ethernet –1 Channel (Min)
Operating Temperature –(-40 to 125C)
Supply Voltage -3.3V
AEC Qualified
Thanks & Regards,
Suriyaprakasam C
lukaszadrapa
take a look at this one, it should fit your needs:
MPC574xB/C/G|32-bit MCU|Gateway|NXP
Lukas
suriyaprakasamc
Hi Lukas,
Thanks for your support
Can you suggest alternate for 5748G because it is too costly. please, specify if any special controller series available in Nxp for Electric Vehicle communication controller ECU in Dc level 2 Application(V2G).
Suriyaprakasam
jingpan
Dear Suriyaprakasam,
I think when we tall about V2G, that is a big system, include power management, communication, metering and measurement. So can you give some detail information about what you want.
http://www.nxp.com/applications/internet-of-things/smart-things/smart-energy/off-grid-solar-power-in...
