I tried the example from LPCOpen for testing the peripheral sdmmc. But it always writes an 1 in the Card detection register, which means that it did not got detected.
I would be nice if somebody could help me.
Hi Eugenr,
Have you tried using a different SD card? What type of SD card are you using? I have done some tests using 3 different SDHC memories (two 8 GB and one 4 GB ) and the example works correctly:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
