The router node can not join the network:
liuxiang
I use a coordinator and a router, the two nodes of the key configuration as shown in Figure:
When the coordinator to establish a network and allow access, the router calls BDB_eNsStartNwkSteering () function, but can not access the network, capturing Packet LOG found the following
When the coordinator returns the secret key, the router does not respond and re-associate request the coordinator
please help me analyze, thank you.
mario_castaneda
Hi Lui,
What is the AN that you are working on? Are you scanning all the channels or did you select only only one? Also the end device.
Can you join the other device without the security?
Mario
