Battery consumption by mma8652
saitejanalamala
I am using mma8652 in normal mode with ODR 50hz, FIFO and tap interrupt are being used.What might be the battery consumption in this configuration?
Here I am observing more current consumption, how could I avoid this.
Any suggestion.
david_diaz
The Table 5 from the datasheet shows the expected current consumption in regard with the power mode and ODR selected.
Please find more information at the sample project from the link below.
MMA8652FC - Auto-WAKE/SLEEP mode
Please let me know if this information is useful for you.
David
