Hi:
I used ADC to collect voltage, the error difference of more than 100 mV, I also read the ADC datasheet, as if ADC needs calibration before use, but I do not know how to calibrate, calibration configuration ADC which registers?
pls help me,Thank you!
xie
The ADC calibration is described in the RM. See chapter 39.5.6 Calibration function for steps that must be done; http://www.nxp.com/assets/documents/data/en/reference-manuals/S32K-RM.pdf
BR, Petr
