Perf test failing with following error,
bash-3.2# perf test 1: vmlinux symtab matches kallsyms : FAILED! 6: Validate PERF_RECORD_* events & perf_sample fields : FAILED! 16: Try 'import perf' in python, checking link problems : FAILED! 17: Test breakpoint overflow signal handler : FAILED! 18: Test breakpoint overflow sampling : FAILED! 19: Test number of exit event of a simple workload : FAILED! 21: Test object code reading : FAILED!
When I ran
bash-3.2# perf test -v 1
--- start ---
test child forked, pid 194
Looking at the vmlinux_path (7 entries long)
Couldn't find a vmlinux that matches the kernel running on this machine, skipping test
test child finished with 254
---- end ----
vmlinux symtab matches kallsyms: FAILED!
I have attached complete test log.
I found this https://forum.odroid.com/viewtopic.php?f=8&t=1581 where it mentioned after kernel version 3.6 perf is broken.
Have anyone tried to do perf testing on IMX6dl board?
Vishnu
Original Attachment has been moved to: perf-test.log.zip
Hi Vishnu
one can try with nxp releases on
in general, as this is specific kernel issue it may be posted on kernel mail list
