How about S32K SPI bitsPerSec when work at master mode?
hansonhe
Dear,
We set S32K lpspiSrcClk=56000000U, how about the SPI bitsPerSec when work at master mode?
now we could only achieve 7000000U, Thanks. We want to achieve 28000000U.
razva_tilimpea
If you want to use the LPSPI at high clock speed is mandatory to use it in DMA mode.
I will try to come back with a working project, but I think that your clock speed it too high.
Razvan
PetrS
The max SPI baud rate is 24MHz in high speed mode as per the datasheet.
BR, Petr
