I would like to cross compile a QT demo image for Sabreauto using QT5.9.
I checkedout morty using repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b morty
I can see only two bitbake options for toolchain in morty
meta-toolchain
meta-extsdk-toolchain
which is relevant for QT?
Did anyone cross compile QT5.9 using morty's CC version?
Mahesh.
current bsp doesnt have qt5.9, if you need to use this, you need to port the qt 5.9 to your board, for detailed information, you need to refer qt documents
