IMX6UL ethernet issue
Question asked by Dinesh Sehrawat on Jun 15, 2017
i am using the customized board based on imx6UL using Linux. While i ma booting my board with sdcard then ethernet is working fine on u-boot, i am able to ping b/w board and laptop. But when i am booting my board using imx6 usb loader then ethernet is not working on u-boot.
In both cases u-boot.imx is same.
Below are the logs:-
board_mmc_init...
switch to partitions #0, OK
mmc1 is current device
Net: Phy 1 not found
PHY reset timed out
FEC0
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
Hit any key to stop autoboot: 0
Bad Linux ARM zImage magic!
Thanks-
Dinesh
