We (Yakov Shaulov and I) created custom board based on imx6slevk bsp and we connected parallel camera (gc0309 640x480 sensor) - created driver based on ov5640 located at subdev folder)
when we are trying to capture an image (using "gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! jpegenc ! filesink location=capture.jpeg") most of the time we get "mx6s_csi_irq_handler Rx fifo overflow" and the image we get is corrupt
Original Attachment has been moved to: imx6sl_kernel_log.txt.zip
Hi Nadav
before using gstreamer please try some basic camera unit tests in
imx-test-..test/pxp_v4l2_test
www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
if it works then try gstreamer using sect.7.3.3 Video encoding
attached Linux Guide.
Please use nxp gstreamer plugins (fsl-gst-plugin) and official bsp releases described on
i.MX 6 / i.MX 7 Series Software and Development Tool|NXP
