ERROR: wfd-sink-2.20-r0 do_fetch: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/media/user1/mydrive/miracast_murata/fsl-release-bsp/downloads//git2/sw-stash.freescale.net.mss.wfd_stack_miracast.git'...
ssh: Could not resolve hostname sw-stash.freescale.net: No address associated with hostname
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
ERROR: wfd-sink-2.20-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://git@sw-stash.freescale.net/mss/wfd_stack_miracast.git;protocol=ssh;branch=wfd_sink_integration_v2'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /media/user1/mydrive/miracast_murata/fsl-release-bsp/bld-miracast/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/wfd-sink/2.20-r0/temp/log.do_fetch.3951
ERROR: Task 335 (/media/user1/mydrive/miracast_murata/fsl-release-bsp/sources/meta-embplug-miracast/recipes-multimedia/wfd-sink/wfd-sink.bb, do_fetch) failed with exit code '1'
This is the error log I've seen during bitbake egl-embplug-miracast-murata. I guess that the link to fetch is obsolete. Please suggest a solution. Igor1z
