Hi team,
Do we have any examples of interruption by a rising edge?
Hi lohrsistemas,
In case you have Matlab and you are familiar with model based design - then you can create your own examples very easily. Even if you do not want to use it for final product development it can be a good resource to generate C-code examples since it is based on the same S32K SDK release.
This is a snippet of that you can do with it:
If interested you can get if from here: https://community.nxp.com/docs/DOC-334170
Hope it helps!
*Daniel
Power_Manager SDK Example uses a port interrupt on PTC13 to wake up from a sleep mode. This is the only example we have, unfortunately.
