1.LPC2294, P3, [27] WE write so why do you configure the register or invalid?
2.The P3 [27] voltage is 2.3 V. But the ARM end segment is 3.3 V for CSO P1 [0] and P1 [1].
3. but the P3 [27] can be configured to be used for general IO, which can be printed at low and low points, 0 and 3.3 V.
Error for :
Programming failed @ address 0x80000000(item verification error)
Failed to program target
Failed to program and verify target
Solved! Go to Solution.
Most of the times, it would be required to generate a proper configuration file according to the used external memory. You could take a look at the following links, that may provide useful related information, depending of the hardware, IDE and debug tool:
https://www.lpcware.com/content/forum/help-j-link-program
https://www.embeddedrelated.com/showthread/lpc2000/8706-1.php
http://www.keil.com/forum/6027/
http://forum.segger.com/index.php?page=Thread&threadID=20
https://www.embeddedrelated.com/showthread/lpc2000/35484-1.php
https://www.lpcware.com/content/forum/need-help-programming-external-flash-lpc-link2-board
Hope this will be useful for you.
Best regards!
/Carlos
Best regards!
/Carlos
