What is a good replacement for the LPC1347?
injunear
I am designing a product based on the LPC1347 but that only has about 5 years left in its production run. Are there any pin compatible chips that have a longer life expectancy? What are some other chips that are similar but have a longer life expectancy, please?
Thank you.
Labels (3)
jeremyzhou
Hi Hillbilly Injunear,
the opportunity to serve you.
LPC134x is pin compatible with the LPC11Uxx which have the longer product life.
And I'd highly recommend you can tell me the exactly requirements about the MCU, then I can suggest the more suitable chips for you.
TIC
