About power consumption on MCIMX6Q-SDP with DORMANT mode.
bandarulavanya
Contributor V
HI Yuri Muhin,
Where we can set to achieve dropping of VDDARM_IN and VDDSOC_IN  to 0.9V (by asserting the PMIC_STBY_REQ).
Lavanya
bandarulavanya
Contributor V
Hi Yuri Muhin,
I have solved the reboot issue with ldo_bypass_enable=<1>; in dts file. Previous case it is ldo_bypass_enable=<0>;.
Now after changing to ldo_bypass_enable=<1> it's resuming properly, But my VDDCORE(VDDARM_IN) is still 1.36V it should reduce to 0.9V.
where i need to change this one.
Lavanya
Yuri
  Have You tried in Linux 4.1  ?
$ echo mem > /sys/power/state
Yuri
bandarulavanya
Contributor V
Hi Yuri Muhin,
Lavanya
