Error message in the log file
Question asked by 中嶋 健 on Jun 8, 2017
Latest reply on Jun 18, 2017 by 中嶋 健
To whom it may concern,
I have problem using LPCXpresso 8.2.0. Would anyone help me solving following problem?  I put my comments followed by “K.N>”.
SW used: LPCXpresso 8.2.0
OS: Windows 7 Professional 64bit
Microcomputer: LPC4370
K.N> When I started LPCXpresso, I’ve got following error message and the program was shut down.
“An error has occured. See the log file.
C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.log.”
The following message was added at the same time stamp when I opened the specified file:
!SESSION 2017-06-02 16:24:01.162 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_65
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ja_JP
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2017-06-02 16:24:06.685
!MESSAGE Application error
!STACK 1
java.lang.LinkageError: Error reading class bytes: org.eclipse.ui.internal.WorkbenchPlugin$4
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:572)
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
                   at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:327)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:402)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
                   at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
                   at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
                   at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
                   at org.eclipse.ui.internal.WorkbenchPlugin.initializeContext(WorkbenchPlugin.java:1329)
                   at org.eclipse.ui.internal.Workbench.initializeLazyServices(Workbench.java:2201)
                   at org.eclipse.ui.internal.Workbench.init(Workbench.java:1652)
                   at org.eclipse.ui.internal.Workbench.access$43(Workbench.java:1624)
                   at org.eclipse.ui.internal.Workbench$59.run(Workbench.java:2972)
Caused by: java.util.zip.ZipException: invalid distance too far back
                   at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:164)
                   at org.eclipse.osgi.storage.bundlefile.ZipBundleEntry$ZipBundleEntryInputStream.read(ZipBundleEntry.java:156)
                   at org.eclipse.osgi.storage.StorageUtil.getBytes(StorageUtil.java:195)
                   at org.eclipse.osgi.storage.bundlefile.BundleEntry.getBytes(BundleEntry.java:94)
                   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:568)
                   ... 14 more
K.N>Following message was also recorded at slightly earlier time stamp:
!SESSION 2017-06-02 11:00:00.020 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2017-06-02 11:00:55.652
!MESSAGE Plugin org.eclipse.cdt.ui, extension org.eclipse.ui.decorators, id org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator: Duplicate id found: org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator
!ENTRY org.eclipse.ui 4 4 2017-06-02 11:00:55.683
!MESSAGE Plugin org.eclipse.cdt.ui, extension org.eclipse.ui.decorators, id org.eclipse.cdt.internal.ui.CustomBuildSettingsDecorator: Unknown extension tag found: decorator
!ENTRY org.eclipse.cdt.ui 4 0 2017-06-02 11:30:04.263
!MESSAGE Error in CDT UI during reconcile
!STACK 1
C Model Exception: C Model Status [Element (Project Name).c does not exist.]
                   at org.eclipse.cdt.internal.core.model.CElement.newNotPresentException(CElement.java:484)
                   at org.eclipse.cdt.internal.core.model.TranslationUnit.makeConsistent(TranslationUnit.java:573)
                   at org.eclipse.cdt.internal.core.model.ReconcileWorkingCopyOperation.executeOperation(ReconcileWorkingCopyOperation.java:62)
                   at org.eclipse.cdt.internal.core.model.CModelOperation.execute(CModelOperation.java:341)
                   at org.eclipse.cdt.internal.core.model.CModelOperation.run(CModelOperation.java:607)
                   at org.eclipse.cdt.internal.core.model.CModelOperation.runOperation(CModelOperation.java:635)
                   at org.eclipse.cdt.internal.core.model.WorkingCopy.reconcile(WorkingCopy.java:362)
                   at org.eclipse.cdt.internal.ui.text.CReconcilingStrategy.reconcile(CReconcilingStrategy.java:78)
                   at org.eclipse.cdt.internal.ui.text.CReconcilingStrategy.reconcile(CReconcilingStrategy.java:63)
                   at org.eclipse.cdt.internal.ui.text.CompositeReconcilingStrategy.reconcile(CompositeReconcilingStrategy.java:87)
                   at org.eclipse.cdt.internal.ui.text.CCompositeReconcilingStrategy.reconcile(CCompositeReconcilingStrategy.java:90)
                   at org.eclipse.jface.text.reconciler.MonoReconciler.process(MonoReconciler.java:77)
                   at org.eclipse.cdt.internal.ui.text.CReconciler.process(CReconciler.java:349)
                   at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:206)
!SUBENTRY 1 org.eclipse.cdt.core 4 969 2017-06-02 11:30:04.310
!MESSAGE Element (Project Name).c does not exist.
!ENTRY org.eclipse.cdt.ui 4 0 2017-06-02 11:31:32.746
!STACK 1
!SUBENTRY 1 org.eclipse.cdt.core 4 969 2017-06-02 11:31:32.746
!ENTRY com.crt.log 1 0 2017-06-02 11:35:33.501
!MESSAGE Drivers loaded in 5756 milliseconds
!SESSION 2017-06-02 15:38:59.919 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2017-06-02 15:39:21.386
K.N> Error message did not show up after restarting LPCXPresso. Built seemed to be succeeded.  However, messages have been added to “log file” every time.  Following is the one of example. Would you advice its cause and countermeasures?
!SESSION 2017-06-02 16:40:40.234 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2017-06-02 16:40:49.222
!ENTRY org.eclipse.cdt.make.core 4 0 2017-06-02 16:51:33.281
!MESSAGE Error accessing scanner config file for project
!STACK 1
org.eclipse.core.runtime.CoreException: Error accessing scanner config file for project
                   at org.eclipse.cdt.make.internal.core.scannerconfig.DiscoveredScannerInfoStore.saveDiscoveredScannerInfoToState(DiscoveredScannerInfoStore.java:306)
                   at org.eclipse.cdt.make.internal.core.scannerconfig.DiscoveredPathManager.updateDiscoveredInfo(DiscoveredPathManager.java:255)
                   at com.crt.advproject.specs.CRTPerProjectSICollector.updateScannerConfiguration(CRTPerProjectSICollector.java:77)
                   at org.eclipse.cdt.build.internal.core.scannerconfig.jobs.CfgSCJobsUtil$2.run(CfgSCJobsUtil.java:144)
                   at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                   at org.eclipse.core.runtime.Platform.run(Platform.java:867)
                   at org.eclipse.cdt.build.internal.core.scannerconfig.jobs.CfgSCJobsUtil.updateScannerConfiguration(CfgSCJobsUtil.java:155)
                   at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.build(ScannerConfigBuilder.java:210)
                   at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.build(ScannerConfigBuilder.java:154)
                   at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.build(ScannerConfigBuilder.java:120)
                   at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:205)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:245)
                   at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:300)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:303)
                   at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:262)
                   at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:402)
                   at org.eclipse.core.internal.resources.Project$1.run(Project.java:556)
                   at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2241)
                   at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:534)
                   at org.eclipse.core.internal.resources.Project.build(Project.java:111)
                   at com.crt.ctrlcenter.launch.BuildUtils.buildProjects(BuildUtils.java:163)
                   at com.crt.ctrlcenter.launch.BuildUtils.access$0(BuildUtils.java:156)
                   at com.crt.ctrlcenter.launch.BuildUtils$2.run(BuildUtils.java:137)
                   at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Caused by: java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\lpc_chip_43xx.sc (The requested operation cannot be performed on a file with a user-mapped section open.。)
                   at java.io.FileOutputStream.open0(Native Method)
                   at java.io.FileOutputStream.open(FileOutputStream.java:270)
                   at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
                   at java.io.FileOutputStream.<init>(FileOutputStream.java:162)
                   at org.eclipse.cdt.make.internal.core.scannerconfig.DiscoveredScannerInfoStore.saveDiscoveredScannerInfoToState(DiscoveredScannerInfoStore.java:302)
                   ... 26 more
!SUBENTRY 1 org.eclipse.cdt.make.core 4 -1 2017-06-02 16:51:33.281
!STACK 0
java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\lpc_chip_43xx.sc (The requested operation cannot be performed on a file with a user-mapped section open.)
!ENTRY org.eclipse.cdt.make.core 4 0 2017-06-02 16:51:45.278
!STACK 1
Caused by: java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\(Workspace).sc (The requested operation cannot be performed on a file with a user-mapped section open.)
                   ... 26 more
!SUBENTRY 1 org.eclipse.cdt.make.core 4 -1 2017-06-02 16:51:45.278
!STACK 0
!ENTRY com.crt.log 1 0 2017-06-02 16:52:48.659
!MESSAGE Drivers loaded in 1137 milliseconds
!ENTRY org.eclipse.cdt.make.core 4 0 2017-06-02 16:53:31.743
!STACK 1
                   at com.crt.ctrlcenter.launch.BuildUtils.buildProject(BuildUtils.java:145)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils.buildProject(BuildLaunchUtils.java:190)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils.buildWithProgress(BuildLaunchUtils.java:1325)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils.access$0(BuildLaunchUtils.java:1309)
                   at com.crt.ctrlcenter.launch.BuildLaunchUtils$4.run(BuildLaunchUtils.java:1264)
                   at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: java.io.FileNotFoundException: C:\Users\(User Name)\Documents\LPCXpresso_8.2.0_647\workspace\(Workspace)\.metadata\.plugins\org.eclipse.cdt.make.core\lpc_chip_43xx.sc (The requested operation cannot be performed on a file with a user-mapped section open.)
                   ... 29 more
!SUBENTRY 1 org.eclipse.cdt.make.core 4 -1 2017-06-02 16:53:31.743
!STACK 0
