Conflict in IO MUX Configuration for i.MX6 Dual processor
rammanohar
Hello All,
I have problem in configuring the IO Mux pads, when I try to use these particular signals:
SD4_CMD (B17) & SD4_CLK (E16)
NAND_RE_B (B17) & NAND_WE_B (E16)
Since, I have to use both the interfaces uSDHC4 & NAND there is a conflict for these pins.
Can you please suggest any other options available to have both the signals.
Also attached the IOMUX configured file for your review.#
Ram
