I am new to code warrior, I created first project. But when i click on main.c file. It says, not found. What could be reason for that?
jagrativalecha
I am programming HCS08 series controller. While create project i Selected create check box, then also it says not found.
Plz help, Thanks in advance
Carlos_Mendoza
Hi Valecha,
Could you tell us which CodeWarrior version are you using? Have you modified the project files outside the IDE?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
jagrativalecha
I am using Code Warrior 6.3.1...
No, I haven't modified any files till now.
