MCD_Toolbox installing problem: Can't see the Toolbox blocksets in Simulink Library
xinyuwang
Hello, NXP engineers
I am trying to use Toolbox for my project. After running  mbd_pnt_path, the result is successful. as the capture:
But I can not find the blockset in simulink bowser:
thanks!
Owen
dumitru-daniel_
Hi Owen,
Please open the Simulink Library Browser and click on F5 to refresh the list.
Usually the Simulink should display this message and should allow you to fix the problem:
Then you should select: Generate Repositories in memory
Hope this helps!
xinyuwang
thanks for your help. it is helpful.
Owen
