memory usage by boot ROM
jameshe1
Hello Yuri
  Do you know where the flash data is loaded to in the system memory? is the address 0x00907000?
Yuri
You may look at the following regarding SD boot (it is similar to NAND, SPI NOR ones).
How to build bootable SD image (for i.MX6 SL as example)
 You may look at Chapter 8 (System Boot) of i.MX6 D/Q RM for some details.
Yuri
