ls1021atwr build question
Question asked by you you on Jun 1, 2017
Latest reply on Jul 3, 2017 by you you
/work/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr$ bitbake fsl-image-minimal
In the /work/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr directory, compile by command bitbake fsl-image-minimal, it can build succeeded. But I moved the entire compiled code to another directory for compilation and failed to compile,such as: /work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr. We need more people to do development work at the same time, I need to modify the configuration files in the original compiled code environment so that I can compile and develop them in different directories of different computers? We don't want to delete the build_ls1021atwr folder and recompile it
I have modified the following documents, But a lot of mistakes
/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr$ bitbake fsl-image-minimalLoading cache: 100% |##########################################################################################################| ETA:  00:00:00
Loaded 3425 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION        = "1.28.0"
BUILD_SYS         = "i686-linux"
NATIVELSBSTRING   = "Ubuntu-14.04"
TARGET_SYS        = "arm-fsl-linux-gnueabi"
MACHINE           = "ls1021atwr"
DISTRO            = "fsl-qoriq"
DISTRO_VERSION    = "2.0"
TUNE_FEATURES     = "arm armv7a vfp neon callconvention-hard cortexa7"
TARGET_FPU        = "vfp-neon"
meta
meta-yocto
meta-yocto-bsp    = "HEAD:9a211a4a2c1bfcb292dc97d8dcac149bca9e3f1b"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-xfce         = "HEAD:dc5634968b270dde250690609f0015f881db81f2"
meta-freescale    = "HEAD:7facbdb726e2dda0515e084c2066a4b8dd99c6d2"
meta-freescale-internal = "HEAD:4829293f807e35a1111e79763294fc8b98b97810"
meta-freescale-extra = "HEAD:bee911b027e0480b034674d0ddee3fcb06d2e985"
meta-virtualization = "HEAD:042425c1d98bdd7e44a62789bd03b375045266f5"
meta-java         = "HEAD:8b776ac68f9af4596be3824152bcf0bc6b67fa1d"
meta-openstack
meta-openstack-aio-deploy
meta-openstack-compute-deploy
meta-openstack-compute-test-config
meta-openstack-controller-deploy
meta-openstack-controller-test-config
meta-openstack-qemu
meta-openstack-swift-deploy
meta-cloud-services = "HEAD:d8bc0d92d0f741e2ea1e6d3d9bc6b7a091d03cfb"
meta-security     = "HEAD:f9367e71f923fc7d2fb600208e2b97535ea41777"
meta-linaro-toolchain = "HEAD:10b71bed9cfe76baa22c72806ff814cf85c2f73b"
NOTE: Preparing RunQueue
WARNING: /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_4.1.bb.do_compile is tainted from a forced run
NOTE: Checking sstate mirror object availability (for 2 objects)
NOTE: Executing SetScene Tasks
ERROR: The recipe run-postinsts is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/run-postinsts
Please verify which recipe should provide the above files.
The build has stopped as continuing in this scenario WILL break things, if not now, possibly in the future (we've seen builds fail several months later). If the system knew how to recover from this automatically it would however there are several different scenarios which can result in this and we don't know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error however switching DISTRO_FEATURES on an existing build directory is not supported, you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: If the above message is too much, the simpler version is you're advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/all-fsl-linux/run-postinsts/1.0-r9/temp/log.do_populate_sysroot_setscene.4715
WARNING: Setscene task 87 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/run-postinsts/run-postinsts_1.0.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe u-boot-qoriq is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/ls1021atwr/u-boot-qoriq-dev-2016.01+fslgit-r0.ls1021atwr.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/ls1021atwr/u-boot-qoriq-2016.01+fslgit-r0.ls1021atwr.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/ls1021atwr/u-boot-qoriq-dbg-2016.01+fslgit-r0.ls1021atwr.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/ls1021atwr-fsl-linux-gnueabi/u-boot-qoriq/2016.01+fslgit-r0/temp/log.do_package_write_rpm_setscene.4713
WARNING: Setscene task 26 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2016.01.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/u-boot-qoriq
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/virtual_bootloader
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/ls1021atwr-fsl-linux-gnueabi/u-boot-qoriq/2016.01+fslgit-r0/temp/log.do_populate_sysroot_setscene.4712
WARNING: Setscene task 20 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2016.01.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe createrepo-native is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/rpm-createsolvedb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/modifyrepo
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/createrepo.real
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/readMetadata.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/dumpMetadata.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/modifyrepo.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/genpkgmetadata.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/sysroot-providers/createrepo-native
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/i686-linux/createrepo-native/0.4.11-r9/temp/log.do_populate_sysroot_setscene.4714
WARNING: Setscene task 49 (virtual:native:/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-support/createrepo/createrepo_0.4.11.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/run-postinsts
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/run-postinsts-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/run-postinsts-dev
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/all-fsl-linux/run-postinsts/1.0-r9/temp/log.do_packagedata_setscene.4755
WARNING: Setscene task 89 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/run-postinsts/run-postinsts_1.0.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe modutils-initscripts is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/modutils-initscripts
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/modutils-initscripts/1.0-r7/temp/log.do_populate_sysroot_setscene.4788
WARNING: Setscene task 241 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe base-passwd is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-dev-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-update-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-doc-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-dbg-3.5.29-r0.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/base-passwd/3.5.29-r0/temp/log.do_package_write_rpm_setscene.4774
WARNING: Setscene task 234 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/base-passwd/base-passwd_3.5.29.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/u-boot-qoriq
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-images
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/u-boot-qoriq-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/u-boot-qoriq-dev
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/ls1021atwr-fsl-linux-gnueabi/u-boot-qoriq/2016.01+fslgit-r0/temp/log.do_packagedata_setscene.4770
WARNING: Setscene task 23 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2016.01.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/modutils-initscripts-dev-1.0-r7.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/modutils-initscripts-dbg-1.0-r7.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/modutils-initscripts-1.0-r7.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/modutils-initscripts/1.0-r7/temp/log.do_package_write_rpm_setscene.4843
WARNING: Setscene task 246 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/base-passwd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-update
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-doc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-update.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-update
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-dev
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/base-passwd/3.5.29-r0/temp/log.do_packagedata_setscene.4891
WARNING: Setscene task 231 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/base-passwd/base-passwd_3.5.29.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/modutils-initscripts
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/modutils-initscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/modutils-initscripts-dbg
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/modutils-initscripts/1.0-r7/temp/log.do_packagedata_setscene.4921
WARNING: Setscene task 243 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/base-passwd/group.master
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/base-passwd/passwd.master
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/base-passwd
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/base-passwd/3.5.29-r0/temp/log.do_populate_sysroot_setscene.5055
WARNING: Setscene task 229 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/base-passwd/base-passwd_3.5.29.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe lsbinitscripts is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/lsbinitscripts
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/lsbinitscripts/9.64-r0/temp/log.do_populate_sysroot_setscene.5062
WARNING: Setscene task 283 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-extended/lsb/lsbinitscripts_9.64.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/lsbinitscripts-dev-9.64-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/lsbinitscripts-9.64-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/lsbinitscripts-dbg-9.64-r0.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/lsbinitscripts/9.64-r0/temp/log.do_package_write_rpm_setscene.5115
WARNING: Setscene task 288 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-extended/lsb/lsbinitscripts_9.64.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/lsbinitscripts
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/lsbinitscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/lsbinitscripts-dbg
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/lsbinitscripts/9.64-r0/temp/log.do_packagedata_setscene.5188
WARNING: Setscene task 285 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-extended/lsb/lsbinitscripts_9.64.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe util-linux is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fsck.cramfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-ja-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-eu-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-staticdev-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-readprofile-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-zh-tw-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-ru-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-cs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-bash-completion-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libblkid1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fstrim-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-findfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-id-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fsck-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-fi-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-swaponoff-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-hu-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-zh-cn-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-vi-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libsmartcols1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-et-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mkfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-blkid-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-agetty-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-de-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-pl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-doc-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-gl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fdisk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-tr-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libmount1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-uuidgen-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-reset-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mkfs.cramfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-sfdisk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-lscpu-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-getopt-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-partx-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-umount-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-sl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-dev-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-sulogin-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-it-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-cfdisk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-losetup-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-uuidd-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-es-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-uk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-hr-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-pt-br-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mcookie-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-dbg-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-sv-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-da-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-hwclock-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-ca-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libuuid1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mount-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-fr-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libfdisk1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-nl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_package_write_rpm_setscene.4920
WARNING: Setscene task 282 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/util-linux/util-linux_2.26.2.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libuuid.so.1.3.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libsmartcols.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libblkid.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libfdisk.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libmount.so.1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libmount.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/utmpdump
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/lsblk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ionice
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/col
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fstrim
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/rtcwake
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/sfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/wdctl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/wipefs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/whereis
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/delpart
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/setsid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/swapon
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/resizepart
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ldattach
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/rename
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mcookie
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/tailf
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/column
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/blockdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/write
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/look
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/chrt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/lscpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/cal
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/colcrt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fsck.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/unshare
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fallocate
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/isosize
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mesg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/nsenter
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/findmnt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/blkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/lslocks
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/blkdiscard
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkfs.bfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/hexdump
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/cfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkfs.minix
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/wall
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkfs.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/renice
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/chcpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/more
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/readprofile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/taskset
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/addpart
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/scriptreplay
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/hwclock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/setterm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/getopt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ipcs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/last
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/losetup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/prlimit
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/pg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/namei
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fdformat
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ipcrm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/colrm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/raw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fsfreeze
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/zramctl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/dmesg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/logger
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/uuidd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/uuidgen
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/rev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/swaplabel
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ctrlaltdel
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/setarch
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/flock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkswap
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ul
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fsck.minix
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/pivot_root
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/partx
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/eject
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mountpoint
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libsmartcols.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libsmartcols.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libfdisk.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libuuid.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libuuid.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libmount.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libmount.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libblkid.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libblkid.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libuuid.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libfdisk.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libblkid.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libsmartcols.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libmount.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libfdisk.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/fdisk.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/uuid.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/smartcols.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/blkid.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/mount.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/libfdisk/libfdisk.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/blkid/blkid.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/libsmartcols/libsmartcols.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/uuid/uuid.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/libmount/libmount.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/util-linux
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_populate_sysroot_setscene.4866
WARNING: Setscene task 277 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/util-linux/util-linux_2.26.2.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe binutils-native is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libbfd.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libopcodes.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libbfd.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libiberty.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libopcodes.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/plugin-api.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/ansidecl.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/dis-asm.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/bfd.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/symcat.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/bfdlink.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/partition.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/splay-tree.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/sort.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/ansidecl.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/fibheap.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/dyn-string.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/floatformat.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/objalloc.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/timeval-utils.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/safe-ctype.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/hashtab.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/demangle.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/libiberty.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/sysroot-providers/binutils-native
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/i686-linux/binutils-native/linaro-2.25-r2015.01/temp/log.do_populate_sysroot_setscene.5171
WARNING: Setscene task 297 (virtual:native:/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-linaro/meta-linaro-toolchain/recipes-devtools/binutils/binutils_linaro-2.25.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe python is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-debugger-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-dev-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-xmlrpc-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-sqlite3-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-datetime-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-man-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-db-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-mime-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-audio-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-syslog-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libpython2.7-1.0-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-resource-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-unittest-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-robotparser-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pprint-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-importlib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-netclient-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-tkinter-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-xml-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-unixadmin-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-image-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-2to3-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-fcntl-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-crypt-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pickle-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-tests-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-dbg-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-logging-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-compiler-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-modules-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-gdbm-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-mmap-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-mailbox-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-numbers-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-readline-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-distutils-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-textutils-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-subprocess-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-codecs-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-argparse-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-distutils-staticdev-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-elementtree-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-idle-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-bsddb-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-hotshot-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-stringold-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-sqlite3-tests-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-smtpd-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-shell-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-contextlib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-email-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-lang-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-multiprocessing-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-misc-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-re-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-html-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pydoc-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-netserver-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pkgutil-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-difflib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-profile-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-curses-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-math-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-compile-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-compression-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-json-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-core-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-zlib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-io-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-terminal-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-ctypes-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-doctest-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-threading-2.7.9-r1.cortexa7hf_vfp_neon.rpm
Please verify which recipe should provide the above files.
The build has stopped as continuing in this scenario WILL break things, if not now, possibly in the future (we've seen builds fail several months later). If the system knew how to recover from this automatically it would however there are several different scenarios which can result in this and we don't know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error however switching DISTRO_FEATURES on an existing build directory is not supported, you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: If the above message is too much, the simpler version is you're advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/python/2.7.9-r1/temp/log.do_package_write_rpm_setscene.5731
WARNING: Setscene task 402 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.9.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/util-linux
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/cs-translation/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/hu-translation/util-linux-locale-hu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/nl-translation/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/sl-translation/util-linux-locale-sl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/ca-translation/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/es-translation/util-linux-locale-es
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libblkid-dev/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libmount-dev/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/da-translation/util-linux-locale-da
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/zh-tw-translation/util-linux-locale-zh-tw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libsmartcols/util-linux-libsmartcols
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/uk-translation/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libmount/util-linux-libmount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-fr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-hu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-zh-cn
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-es
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-da
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-sl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-gl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-et
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-zh-tw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/tr-translation/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/et-translation/util-linux-locale-et
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libblkid/util-linux-libblkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libfdisk/util-linux-libfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libsmartcols
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libmount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libblkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libuuid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/ru-translation/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/zh-cn-translation/util-linux-locale-zh-cn
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/de-translation/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/ja-translation/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libuuid-dev/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/pl-translation/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/it-translation/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libuuid/util-linux-libuuid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/eu-translation/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/vi-translation/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/sv-translation/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/id-translation/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/gl-translation/util-linux-locale-gl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/fi-translation/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/hr-translation/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/fr-translation/util-linux-locale-fr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/pt-br-translation/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mkfs.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-da.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-readprofile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-sl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-readprofile.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-hu.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mcookie.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fsck.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-zh-cn.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-bash-completion.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-staticdev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-reset
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fstrim.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mount.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libuuid.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-umount.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-losetup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-fr.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-id.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-uuidgen.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libsmartcols
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-blkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-swaponoff.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-es.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libmount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-sfdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-findfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-partx
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mkfs.cramfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-losetup.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-partx.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-et.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-lscpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-getopt.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libblkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-reset.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-cfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-findfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libmount.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-fi.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-agetty
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-vi.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-gl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-sulogin.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-cs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-de.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mkfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ja.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-doc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-lscpu.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-hr.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-nl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-sv.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pt-br.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-uk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fsck.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-uuidd.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libsmartcols.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fsck.cramfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-tr.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-blkid.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-eu.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-it.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ru.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-zh-tw.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-hwclock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-hwclock.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libfdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-cfdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libblkid.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-agetty.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ca.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-mkfs.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-readprofile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-fsck.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-reset
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libuuid1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-fstrim
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-mount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-losetup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-bash-completion
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-mcookie
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-blkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-findfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-partx
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-fr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-lscpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-umount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-cfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-agetty
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-hu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-fdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-getopt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libmount1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-sulogin
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libfdisk1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libsmartcols1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-zh-cn
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-uuidd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-swaponoff
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-es
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libblkid1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-da
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-uuidgen
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-hwclock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-sl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-gl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-et
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-zh-tw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-sfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libblkid.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libmount.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libfdisk.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libsmartcols.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libuuid.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-dev.pclist
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_packagedata_setscene.5622
WARNING: Setscene task 279 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/util-linux/util-linux_2.26.2.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe ossp-uuid-native is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/uuid-config
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.so.16
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.so.16.0.22
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/pkgconfig/ossp-uuid.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/ossp/uuid.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/sysroot-providers/ossp-uuid-native
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/i686-linux/ossp-uuid-native/1.6.2-r2/temp/log.do_populate_sysroot_setscene.6897
WARNING: Setscene task 169 (virtual:native:/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/ossp-uuid/ossp-uuid_1.6.2.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/python
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/libpython2/libpython2
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/python/python-core
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.7.9)/libpython2
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-elementtree.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-unixadmin
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-xml.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mime.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-unittest.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-io.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-stringold.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-idle.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-netclient.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-readline.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-audio
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-syslog
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mmap
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-core.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-math.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-crypt.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-misc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-multiprocessing
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compiler
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tkinter
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-modules
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-curses.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-argparse.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-importlib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-terminal.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-profile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-syslog.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-netserver.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pprint
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pickle.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-html
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-threading.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-image
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-unixadmin.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-shell
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-json
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pprint.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-audio.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-numbers
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-modules.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-lang.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-sqlite3-tests.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-xmlrpc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compression
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-debugger.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-html.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mmap.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-datetime.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-db.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-image.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mailbox
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-hotshot
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-fcntl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-zlib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compiler.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-robotparser.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-email
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-man.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/libpython2
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-resource
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-subprocess
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-logging
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tkinter.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-doctest.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-logging.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-textutils.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pydoc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-contextlib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils-staticdev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-difflib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-resource.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-2to3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-2to3.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-sqlite3.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-json.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-shell.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-re.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compression.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-smtpd.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-difflib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-hotshot.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-bsddb
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-profile.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compile.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mailbox.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tests.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pydoc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-numbers.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pkgutil
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-ctypes.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-gdbm.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-codecs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-bsddb.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-email.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-xmlrpc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pkgutil.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-subprocess.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-multiprocessing.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/libpython2.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-unixadmin
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-xml
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-distutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-audio
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-syslog
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-re
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-mmap
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-multiprocessing
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-compiler
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-tkinter
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-modules
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-profile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pprint
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-html
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-unittest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-image
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-elementtree
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-shell
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-json
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-numbers
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-xmlrpc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-compression
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-distutils-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-crypt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-stringold
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-argparse
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-mailbox
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-hotshot
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-mime
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-db
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-datetime
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-debugger
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-fcntl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-lang
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-idle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-email
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-resource
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-subprocess
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-logging
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-threading
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-robotparser
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-terminal
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pydoc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-difflib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-importlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-curses
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-2to3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-math
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-core
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pickle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-contextlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-smtpd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-bsddb
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-netserver
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-sqlite3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-doctest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-misc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pkgutil
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-sqlite3-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libpython2.7-1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-textutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-zlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-man
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-ctypes
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-codecs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-netclient
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-readline
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-io
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-gdbm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/libpython2.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/python-dev.pclist
Please verify which recipe should provide the above files.
The build has stopped as continuing in this scenario WILL break things, if not now, possibly in the future (we've seen builds fail several months later). If the system knew how to recover from this automatically it would however there are several different scenarios which can result in this and we don't know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error however switching DISTRO_FEATURES on an existing build directory is not supported, you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: If the above message is too much, the simpler version is you're advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/python/2.7.9-r1/temp/log.do_packagedata_setscene.6899
WARNING: Setscene task 399 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.9.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe python is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libpython2.7.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libpython2.7.so.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/python.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/python-2.7.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/python2.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cProfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bisect.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Cookie.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/asynchat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_compile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/io.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pyclbr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/zipfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mailbox.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/htmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urllib2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/heapq.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/MimeWriter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pdb.doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/htmlentitydefs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/md5.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref.egg-info
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/zipfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cProfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pipes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/imaplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sitecustomize.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/nturl2path.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pydoc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/argparse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/this.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pkgutil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/keyword.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ihooks.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/__phello__.foo.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pty.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cookielib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_parse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/macpath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/binhex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/difflib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/functools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/keyword.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/webbrowser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fileinput.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sndhdr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mailcap.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimetools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/os2emxpath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cmd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/imputil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fpformat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/getpass.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hmac.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pprint.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/telnetlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_weakrefset.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/macpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/shelve.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/code.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/aifc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sysconfig.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urllib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/base64.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/repr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/trace.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/genericpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/netrc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_osx_support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rfc822.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/colorsys.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/linecache.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ihooks.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multifile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sgmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/gettext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/argparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plistlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pyclbr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/commands.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/nntplib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stat.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/SimpleHTTPServer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_compile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/smtplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wave.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/traceback.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/atexit.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/csv.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/locale.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/LICENSE.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compileall.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserString.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/poplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimetypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stringold.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sets.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/posixfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sched.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fractions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/py_compile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/warnings.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dummy_threading.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stringprep.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/smtpd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/optparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/platform.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/random.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserList.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/opcode.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cgitb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hashlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tabnanny.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/SimpleXMLRPCServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fnmatch.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sha.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rexec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ssl.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/profile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/base64.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bdb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/posixpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/asyncore.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tokenize.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/string.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/decimal.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/anydbm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/repr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pickletools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/textwrap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/robotparser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_strptime.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/__phello__.foo.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pty.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/py_compile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sha.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/runpy.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/toaiff.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/smtpd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/contextlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ntpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/opcode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/uu.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/numbers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cgi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ftplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/symtable.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ast.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/CGIHTTPServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dbhash.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xmlrpclib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/commands.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/timeit.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urlparse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_LWPCookieJar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ConfigParser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mutex.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserDict.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/macurl2path.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/shutil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/BaseHTTPServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/copy_reg.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/site.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tarfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/inspect.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sndhdr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/new.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pdb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/gzip.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dumbdbm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_MozillaCookieJar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_parse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/uuid.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pprint.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_pyio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rlcompleter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/doctest.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/chunk.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/platform.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/atexit.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_constants.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/inspect.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/anydbm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dis.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sunaudio.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/collections.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dis.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_sysconfigdata.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/shlex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/profile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dummy_thread.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/netrc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/socket.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/DocXMLRPCServer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/contextlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/telnetlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_LWPCookieJar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/doctest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Bastion.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/aifc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimetools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/symbol.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/httplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sunau.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/__future__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/codecs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/os.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_constants.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/markupbase.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/csv.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Queue.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/re.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/token.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cmd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserList.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserString.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/chunk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/traceback.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xmlrpclib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/threading.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rfc822.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cgitb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ssl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/threading.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimify.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sunaudio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/calendar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/copy.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/HTMLParser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/MimeWriter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Bastion.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tempfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/struct.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sysconfig.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/getopt.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/calendar.pyc
