RodirgoLetang
Problems with the Timer interrupts on MC56F8025
Discussion created by RodirgoLetang on Aug 18, 2008
Latest reply on Oct 30, 2008 by Pascal Irrle
DSC: MC56F8025
Code Warrior Version: 8.2.2
I´d made a code on C programming language to MC56F8013 using timer interrupts and it's working properly.Then, I'd made a similar code to MC56F8025 and it isn't working: when the timer counter reach the COMP1 value, the flags turns on, but the interrupt doesn't occur in spite of the interrupt is enabled and the interrupt vector is configured.
I need some help to fix this problem. An example of a code on C programming language to MC56F8025 using timer interrupt would be helpfull.
Thanks!
Rodrigo Letang
