Is it possible to get the i.MX6QP SABRE AI CPU board layout file (Allegro/OrCAD *.brd file)? It seems that this file is not included in the publicly available design files.
Solved! Go to Solution.
Hello Kari Kumpulainen,
You may find the Design Files for the i.MX6QP SABRE AI CPU3 on the link below (please note you may need to login to download this file).
Inside you should find the .brd file for the layout
I hope this information helps!
