EEE_Driver_v1.3.0 - Memory check in eepromConf
akhilprasad
Currently we are using the MPC5604S controller and NVM package version EEE_Driver_v1.3.0.
We shall need to Check how much memory is left in the current EEE section and based on that emergency write will be called.
Please confirm is there any command or function available to check the space left in EEL section or eepromConf ?
