I encountered a problem when used S32D to flashing the MPC5748G.
The window pop up when i debugged.
the debugger is OpenSDA.
please help me ...
Solved! Go to Solution.
please measure reset line immediately after power on. If you do not see the signal (see picture below), but reset line is in 0 all time, your microcontroller is "dead".
Reason of this behavior is described in this thread.
https://community.nxp.com/message/877631
Martin
I suppose you use MPC5748G Devkit.
Martin
Hello Martin,
Thanks for your reply.
I use the MPC5748G Devkit.
The S32D version is 1.1 and for power PC.
I use the USB to power this board and I can see a red LED on all the time.
I think i have installed the PEMicro because i can program the board at the begining,but after several times the window poped up.
Martin
Hello Martin,
I think I can‘t solve the problem by myself,I will ask for a NXP engineer to help me sovle this problem at the scene.
Thank you all the same!
