Cyclone Universal programing CW6.3 s-record file issue
dannydeng
Dears,
  I found the issue when I use Cyclone Universal programing CW6.3 s-record file of S9S08DZ60F2MLH, it appeared some mistake 0x00003003 at the Flash address 0x0000F400. While programing CW10.x s-record file, it is well.
   Can anybody give any advice?
  Thanks and best regards,
Ray Deng,
ZhangJennie
Hi Ray,
If your srecord file is generated by CW, please verify the file with CW debugger if its function is correct.
If yes, srecord file is fine. I suggest you contact Cyclone Universal producer P&E.
PEmicro - P&E Microcomputer Systems: Over 30 years as an Industry leader in Embedded Systems Develop...
Jennie Zhang
dannydeng
Hi Jennie,
    Thanks for your kinldy suggestion.
   I will check it.
Ray Deng
ZhangJennie
You are welcome!
Jennie Zhang
