I want to use watchpoints to break when access (read and/or write) data for target board debug.
IAR Systems EWARM supported this feature that "Set Data Breakpoint", KEIL MDK-ARM also supported that "Set access breakpoint".
I found the following description in 4 Known Issues and Workarounds of Kinetis Design Studio 3.2.0 Release Notes.
Therefore I believe that KDS does not support watchpoints debugging to break when access (read and/or write) data.
Am I correct?
How about MCUxpresso? Is it support watchpoints debugging?
Please reply as soon as possible.
Takashima
Hi Isao,
You are correct, this is a known issue in KDS, it is recommended to use normal breakpoints instead of conditional breakpoints or watchpoints. Regarding MCUXpresso, those limitations are not present on this IDE.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
