Hello
I am using the NXP Kinetis K60 (http://www.nxp.com/assets/documents/data/en/reference-manuals/K60P144M150SF3RM.pdf)
Is it possible to adjust the voltage level of the POR? Or is it always fixed at the levels specified by datasheet?
No, Unfortunately this voltage value cannot be modified, it is used to protect MCU to not get damaged when low voltages are detected.
If it works for you, you could use LVD (low voltage detection) system, which has a LVD reset operation, where the low-voltage detection threshold is determined by LVDSC1[LVDV]; you could use LVDL=1.60 or LVDH=2.56.
Hope this information could help you.
Jorge Alcala
