ADC_LDD with PE issue
Question asked by DHRUV A on May 24, 2017
Latest reply on May 26, 2017 by DHRUV A
I am trying to measure the multiple ADC Channels(Single Ended & Differential) using ADC_LDD component. I am unable to get the result any of ADC Channels as expected. Can someone please suggest the measurement or the modifications in the attached code.
When i create the multiple channels in the Sample group setting, it is giving the error "Only 1 samples are supported with this hardware. But Channels count is 8 in the ADC properties.
I have tried using ADC0_CreateSampleGroup function also. But i am not able to get the actual results.
Here is the code attached. Please suggest.
Druv
Original Attachment has been moved to: ADC_Test.rar
