I try to build linux kernel for Warp7.
I do it follow section 5 in GitHub - WaRP7/WaRP7-User-Guide: WaRP7 User Guide Source. For binary releases go to the release tab
But when i run "make ARCH=arm CROSS_COMPILE=......." command to cross compile for "zImage". It always show error below:
make[2]: *** No rule to make target `fs/fat/file.o', needed by `fs/fat/fat.o'. Stop.
make[1]: *** [fs/fat] Error 2
make: *** [fs] Error 2
Is there any package I need to add in my host PC Ubuntu ?
I tried to google-ing about error and fat* file but no hope
Note: I think git source code should be OK when it is commited
source: GitHub - Freescale/linux-fslc: Linux kernel source tree
branch: 4.1-2.0.x.imx
Solved! Go to Solution.
Please try to setup environment as described in section 5
WaRP7-User-Guide/06-Chapter at master · WaRP7/WaRP7-User-Guide · GitHub
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Yuri
button. Thank you!
