how to use sprintf
how to use sprintf
omkar787898
i am trying to display hex value on terminal, but it needs to be char so i can display so i  want to use sprintf but is giving error 1. I added stdio.h also. How i can use sprintf in lpcexpresso?
lpcxpresso_supp
Look in the Build Log (The Build Console ) or the Problems View to find the actual error you are encountering, rather than just looking at the final "error 1" message.
The most likely cause of problems calling sprintf() though are that you are linking with the wrong library variant. You need to use "nohost" or "semihost". For more details see:
Alternatively, you might also want to check out the itoa() function:
https://community.nxp.com/message/630652
LPCXpresso Support
