imx6q Sabre Automotive infotainment Board Boot Error
Question asked by nandish gurulingappa on May 19, 2017
Latest reply on May 23, 2017 by nandish gurulingappa
Hello All,
i am trying to boot the imx6q sabre AI board but i am getting the boot error, earlier it was working fine, then i did "bitbake -c cleanall fsl-image-qt5" and build the iamge one more time "bitbake fsl-image-qt5" its build successfully, after loading and put the SD in board i am getting boot error, and itried to google it but i am not getting proper solution, some of them told inittab file is missing, i don't know what is missing where i am did wrong please help me to come out of this problem, below is the boot  log error,
U-Boot 2014.04 (Sep 08 2016 - 23:19:46)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
CPU:   Temperature 21 C, calibration data: 0x5934d77d
Reset cause: POR
Board: MX6-Sabreauto revA
I2C:   ready
DRAM:  2 GiB
NAND:  0 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
wait_for_sr_state: Arbitration lost sr=33 cr=98 state=202
wait_for_sr_state: failed sr=23 cr=88 state=2000
i2c_imx_stop:trigger stop failed
i2c_init_transfer: failed for chip 0x8 retry=0
wait_for_sr_state: failed sr=21 cr=88 state=2000
i2c_init_transfer: failed for chip 0x8 retry=1
mmc1 is current device
Net:   FEC [PRIME]
Normal Boot
Hit any key to stop autoboot:  0
reading boot.scr
** Unable to read file boot.scr **
reading zImage
5546200 bytes read in 262 ms (20.2 MiB/s)
Booting from mmc ...
reading imx6q-sabreauto.dtb
48933 bytes read in 19 ms (2.5 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x54a0d8 ]
## Flattened Device Tree blob at 18000000
   Booting using the fdt blob at 0x18000000
   Using Device Tree in place at 18000000, end 1800ef24
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.10.53+g496fbe0 (sameer@linux1-tds) (gcc version 4.8.2 (GCC) ) #68 SMP PREEMPT Fri May 19 14:54:38 IST 2017
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Freescale i.MX6 Quad SABRE Automotive Board
cma: CMA: reserved 320 MiB at 6a000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @81d9d000 s8960 r8192 d15616 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520720
Kernel command line: console=ttymxc3,115200 root=/dev/mmcblk2p2 rootwait rw
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 2048MB = 2048MB total
Memory: 1736756k/1736756k available, 360396k reserved, 270336K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0x80000000 - 0xef800000   (1784 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80c71770   (12710 kB)
      .init : 0x80c72000 - 0x80cbe300   ( 305 kB)
      .data : 0x80cc0000 - 0x80d178c0   ( 351 kB)
       .bss : 0x80d178c0 - 0x80d809ac   ( 421 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
CPU identified as i.MX6Q, silicon rev 1.2
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
Mount-cache hash table entries: 512
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x80685b38 - 0x80685b90
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: Booted secondary processor
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: Booted secondary processor
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1125 mV
vdd3p0: 2800 <--> 3150 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2425 mV
cpu: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
cs42888_supply: 3300 mV
vio1: 3300 mV
vio2: 3300 mV
vd: 3300 mV
va: 5000 mV
platform usb_h1_vbus.30: Driver reg-fixed-voltage requests probe deferral
usb_h2_vbus: 5000 mV
platform usb_otg_vbus.32: Driver reg-fixed-voltage requests probe deferral
3P3V: 3300 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
pureg-dummy: no parameters
Switching to clocksource mxc_timer1
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
imx6_busfreq busfreq.15: DDR medium rate not supported.
Bus freq driver module loaded
futex hash table entries: 1024 (order: 4, 65536 bytes)
bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 3504
io scheduler noop registered
MIPI DSI driver module loaded
INIT IS CALLED
LCD_RESET driver probed
INIT IS END
mxc_sdc_fb fb.22: registered mxc display driver lcd
Console: switching to colour frame buffer device 30x40
HANNSTAR PROBE GETTING CALLED
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 1.1
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 0-0008: Full lay: 1, Metal lay: 1
pfuze100-regulator 0-0008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV at 1375 mV
SW1C: 300 <--> 1875 mV at 1375 mV
SW2: 800 <--> 3300 mV
SW3A: 400 <--> 1975 mV at 1500 mV
SW3B: 400 <--> 1975 mV at 1500 mV
SW4: 800 <--> 1975 mV at 1800 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VGEN1: 800 <--> 1550 mV at 800 mV
VGEN2: 800 <--> 1550 mV at 1500 mV
VGEN3: 1800 <--> 3300 mV at 1800 mV
VGEN4: 1800 <--> 3300 mV at 1800 mV
VGEN5: 1800 <--> 3300 mV at 2500 mV
VGEN6: 1800 <--> 3300 mV at 2800 mV
Serial: IMX driver
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
console [ttymxc3] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
si476x-core 0-0063: Using default platform data.
si476x-core 0-0063: No IRQ number specified, will use polling
si476x-core 0-0063: Error while sending command 0x11
si476x-core 0-0063: The device in inconsistent power state
Wait for CR ACK error!
sata phy RX_PLL is stable!
ahci: SSS flag set, parallel bus scan disabled
ahci ahci: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
spi_imx 2008000.ecspi: can't get cs gpios
spi_imx: probe of 2008000.ecspi failed with error -16
CAN device driver interface
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_KEY_ROW4 already requested by usbphy_nop1.12; cannot claim for 2094000.can
imx6q-pinctrl 20e0000.iomuxc: pin-135 (2094000.can) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 135 on device 20e0000.iomuxc
flexcan 2094000.can: Error applying setting, reverse things back
flexcan: probe of 2094000.can failed with error -22
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
platform 2184000.usb: Driver imx_usb requests probe deferral
imx_usb 2184200.usb: Can't register ci_hdrc platform device, err=-517
platform 2184200.usb: Driver imx_usb requests probe deferral
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_RGMII_TXC already requested by 2188000.ethernet; cannot claim for 2184400.usb
imx6q-pinctrl 20e0000.iomuxc: pin-22 (2184400.usb) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 22 on device 20e0000.iomuxc
imx_usb 2184400.usb: Error applying setting, reverse things back
imx_usb 2184400.usb: hsic_idle select failed, err=-22
imx_usb: probe of 2184400.usb failed with error -22
mousedev: PS/2 mouse device common for all mice
egalax_ts 0-0004: Failed to read firmware version
egalax_ts: probe of 0-0004 failed with error -5
input: isl29023 light sensor as /devices/virtual/input/input0
isl29023 1-0044: driver version 1.0 enabled
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
mxc_v4l2_output v4l2_out.39: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.39: V4L2 device registered as video17
mag3110 1-000e: check mag3110 chip ID
input: mag3110 as /devices/virtual/input/input1
mag3110 1-000e: mag3110 is probed
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
ata1: SATA link down (SStatus 0 SControl 300)
input: mma845x as /devices/virtual/input/input2
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
usbcore: registered new interface driver ath3k
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
Galcore version 5.0.11.25762
mmc2: new high speed SDHC card at address e624
mmcblk2: mmc2:e624 SU08G 7.40 GiB
 mmcblk2: p1 p2
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_asrc 2034000.asrc: mxc_asrc registered
mxc_vpu 2040000.vpu: VPU initialized
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a160100 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] 5b 01 37 ae 54 d9 4d 28
platform caam_sm: [0008] 5c d7 87 a5 9a 04 bd ae
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 9e 06 37 2d 84 dc a3 1c
platform caam_sm: [0008] 41 15 89 b0 1d 20 51 64
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 9b 40 df fd ce d0 62 df
platform caam_sm: [0008] fe d4 8d 65 77 63 b6 f8
platform caam_sm: [0016] 2d 3f a8 a4 86 41 84 fe
platform caam_sm: [0024] 8a 6a e8 0c 17 31 c8 c8
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 1c 32 a4 6e 54 17 a4 53
platform caam_sm: [0008] 0b 5c 93 4b 9c 0e 8f e8
platform caam_sm: [0016] c4 0a 16 53 75 00 be 42
platform caam_sm: [0024] 93 31 34 06 31 28 46 d0
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] e1 a5 d8 1d 2e 4e 6e fb
platform caam_sm: [0008] ea 9b 93 ee bb c4 25 ff
platform caam_sm: [0016] e9 ab 88 ae a0 55 54 1d
platform caam_sm: [0024] 19 83 39 63 55 b3 79 74
platform caam_sm: [0032] a6 c7 38 9c 31 83 df 6b
platform caam_sm: [0040] 7a e0 7e 81 8f ad 8b 6d
platform caam_sm: [0048] 16 32 14 70 cb f2 d6 27
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 62 0e 5f af 60 ff 5b 81
platform caam_sm: [0008] 90 61 34 68 14 48 61 08
platform caam_sm: [0016] a3 96 31 16 c5 3f 78 28
platform caam_sm: [0024] db 98 ac 2f 93 6b b6 e4
platform caam_sm: [0032] 9b 1f 90 25 77 2a 6f 9f
platform caam_sm: [0040] 82 91 1a 22 6b 0c 3f fb
platform caam_sm: [0048] f9 8f 80 f0 3c 09 6f 3c
platform caam_sm: [0056] 52 b9 e3 20 d2 96 f4 11
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] b9 68 89 2e 62 3b e5 33
platform caam_sm: [0008] f3 06 3f ca a3 88 46 75
platform caam_sm: [0016] 2b 31 fc 4c 3e 13 7d 32
platform caam_sm: [0024] d5 ac 42 1e ba 52 66 8c
platform caam_sm: [0032] 2f ce f4 f4 07 a4 cf 05
platform caam_sm: [0040] d8 d3 07 10 53 a1 fb 13
platform caam_sm: [0048] 22 2d 1d cb 2c fc dd 0b
platform caam_sm: [0056] 4d 42 2f 67 1d 7a be 21
platform caam_sm: [0064] db 92 bd 89 f3 21 54 3e
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 42 95 d0 93 cc 1e 23 ef
platform caam_sm: [0008] fa 0d a8 55 23 df 61 00
platform caam_sm: [0016] 95 ab ab ff 2b bb c7 35
platform caam_sm: [0024] 7a 51 f3 83 ff ef 7b 5e
platform caam_sm: [0032] 2c 80 ac b5 69 05 1b 92
platform caam_sm: [0040] 3b 03 55 e8 a9 d2 45 e9
platform caam_sm: [0048] 42 24 c0 8e c6 f9 47 fa
platform caam_sm: [0056] 15 b2 30 3a ca a5 03 50
platform caam_sm: [0064] 9b fa 4c 91 9d 89 20 94
platform caam_sm: [0072] b2 71 ff 70 78 48 05 d8
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 9f 84 44 57 09 84 d6 0d
platform caam_sm: [0008] 36 68 b9 85 92 82 17 ac
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 76 84 21 a1 71 5b e2 15
platform caam_sm: [0024] 2f f8 fc 8b 85 76 1b 03
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
cs42xx8 0-0048: failed to get the clock: -2
cs42xx8: probe of 0-0048 failed with error -22
fsl-hdmi-dai hdmi_audio.16: failed to probe. Load HDMI-video first.
fsl-hdmi-dai: probe of hdmi_audio.16 failed with error -12
imx-cs42888 sound-cs42888.34: failed to find codec platform device
imx-cs42888: probe of sound-cs42888.34 failed with error -22
imx-spdif sound-spdif.37:  dir-hifi <-> 2004000.spdif mapping ok
imx-audio-hdmi sound-hdmi.36: initialize HDMI-audio failed. load HDMI-video first!
imx-tuner-si476x sound-fm.35: failed to find FM platform device
imx-tuner-si476x: probe of sound-fm.35 failed with error -22
NET: Registered protocol family 26
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
VGEN2: disabling
SWBST: disabling
SW4: disabling
usb_h2_vbus: disabling
regulator-dummy: disabling
imx mcc test is registered.
usb_h1_vbus: 5000 mV
usb_otg_vbus: 5000 mV
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
input: gpio-keys.19 as /devices/soc0/gpio-keys.19/input/input3
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
ALSA device list:
  #0: imx-spdif
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk2p2): warning: mounting fs with errors, running e2fsck is recommended
EXT3-fs (mmcblk2p2): using internal journal
EXT3-fs (mmcblk2p2): recovery complete
EXT3-fs (mmcblk2p2): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 304K (80c72000 - 80cbe000)
INIT: version 2.88 booting
INIT: No inittab file found
Enter runlevel:
Thanks in advance,
nandish sg
