read and write for ntag216
459320356
hello,I have many nfc tags Ntag216. which nfc reader/writer soc can easily read and writer it?   pn532 can do that with arm controller?
if so, any lib for pn532 to develop?
thanks for reply.
fernandohcoelho
If your going to work with Arm and Linux, there are some simple libraries written for Mifare Cards in Python, which is not your case. All libraries I found were in C++ and I had to transport it to Java language to work in Arm. Not a complicated task, but takes a lot of testing.
If it is the first time you are using NFC hardware I recomend you use an Atmel MCU + RC522 shield - all libraries are working fine. After understanding the usage you can write your own Arm code.
Regards!
jimmychan
It is a leaflet of NFC solution.
http://www.nxp.com/documents/leaflet/939775017564.pdf
There are EVKs support ntag216. You can find one that meet your needs.
459320356
anybody can help?
