Hi all
Could someone tell me whether the HS line receiver has rise/fall timing spec or not ?
I'm checking a mipi-csi timing spec with custom board which has i.MX7D.
According to the table 77 of IMX7DCEC Rev. 4, there are no timing spec for rise and fall time in HS Line Receiver.
However, I heard the mipi compliant test has the spec for rise and fall time.
Are there no rise and fall timing spec for HS Line Receiver ?
Ko-hey
Solved! Go to Solution.
Hi Ko-hey
you are right, there is no rise and fall timing spec for HS Line Receiver,
mipi specification defines it only for transmitter.
Hi Ko-hey
