Codewarrior10.6.4 Flash Programmer issue for DSC
tonyyang
I use the Flash programmer to burn a 48KByte bin file to MC56F82733, but I find the MC56F82733's first 8KByte flash have been erased, and the rest is OK.
I also find if no use the second Erase and Program X_FLASH task, all the data can program to the chip. I don't know why the second script can erase the first 8KByte data, and not program the data.
Original Attachment has been moved to: readtest.bin.zip
ZhangJennie
Hi Tony,
To investigate your issue, we need reproduce it first.
Can you please send me your testing .bin file. I will test it from my side.
Jennie Zhang
tonyyang
Hi Jenie,
Please check my attachment, there is a bin file and issue description.
ZhangJennie
Hi Tony.
I don't have exact your chip but I reproduce the similar issue on 56F82748.
This problem was escalated to development team DTDBGPG-849.
I will let you know as soon as I get any feedback there.
Thanks.
Jennie Zhang
tonyyang
Hi Jenie,
I can't get the bin file from the customer due to their rule.
