Hi.
Can you help me how to deal with this error?
I have this code below in my MC9S12XEP100.h file and during compilation I have an error pointed to the highlighted line. Please help me with this..
/*** DBGTB - Debug Trace Buffer Register; 0x00000024 ***/
typedef union {
word Word;
/* Overlapped registers: */
struct {
/*** DBGTBH - Debug Trace Buffer Register High; 0x00000024 ***/
union {
byte Byte;
struct {
byte BIT8 :1;
byte BIT9 :1;
byte BIT10 :1;
byte BIT11 :1;
byte BIT12 :1;
byte BIT13 :1;
byte BIT14 :1;
byte BIT15 :1;
} Bits;
} DBGTBHSTR;
#define DBGTBH _DBGTB.Overlap_STR.DBGTBHSTR.Byte
#define DBGTBH_BIT8 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT8
#define DBGTBH_BIT9 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT9
#define DBGTBH_BIT10 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT10
#define DBGTBH_BIT11 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT11
#define DBGTBH_BIT12 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT12
#define DBGTBH_BIT13 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT13
#define DBGTBH_BIT14 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT14
#define DBGTBH_BIT15 _DBGTB.Overlap_STR.DBGTBHSTR.Bits.BIT15
#define DBGTBH_BIT8_MASK 1
#define DBGTBH_BIT9_MASK 2
#define DBGTBH_BIT10_MASK 4
#define DBGTBH_BIT11_MASK 8
#define DBGTBH_BIT12_MASK 16
#define DBGTBH_BIT13_MASK 32
#define DBGTBH_BIT14_MASK 64
#define DBGTBH_BIT15_MASK 128
/*** DBGTBL - Debug Trace Buffer Register Low; 0x00000025 ***/
union {
byte Byte;
struct {
byte BIT0 :1;
byte BIT1 :1;
byte BIT2 :1;
byte BIT3 :1;
byte BIT4 :1;
byte BIT5 :1;
byte BIT6 :1;
byte BIT7 :1;
} Bits;
} DBGTBLSTR;
#define DBGTBL _DBGTB.Overlap_STR.DBGTBLSTR.Byte
#define DBGTBL_BIT0 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT0
#define DBGTBL_BIT1 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT1
#define DBGTBL_BIT2 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT2
#define DBGTBL_BIT3 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT3
#define DBGTBL_BIT4 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT4
#define DBGTBL_BIT5 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT5
#define DBGTBL_BIT6 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT6
#define DBGTBL_BIT7 _DBGTB.Overlap_STR.DBGTBLSTR.Bits.BIT7
#define DBGTBL_BIT0_MASK 1
#define DBGTBL_BIT1_MASK 2
#define DBGTBL_BIT2_MASK 4
#define DBGTBL_BIT3_MASK 8
#define DBGTBL_BIT4_MASK 16
#define DBGTBL_BIT5_MASK 32
#define DBGTBL_BIT6_MASK 64
#define DBGTBL_BIT7_MASK 128
} Overlap_STR;
struct {
word BIT0 :1;
word BIT1 :1;
word BIT2 :1;
word BIT3 :1;
word BIT4 :1;
word BIT5 :1;
word BIT6 :1;
word BIT7 :1;
word BIT8 :1;
word BIT9 :1;
word BIT10 :1;
word BIT11 :1;
word BIT12 :1;
word BIT13 :1;
word BIT14 :1;
word BIT15 :1;
} Bits;
} DBGTBSTR;
extern volatile DBGTBSTR _DBGTB @(REG_BASE + 0x00000024);
#define DBGTB _DBGTB.Word
#define DBGTB_BIT0 _DBGTB.Bits.BIT0
#define DBGTB_BIT1 _DBGTB.Bits.BIT1
#define DBGTB_BIT2 _DBGTB.Bits.BIT2
#define DBGTB_BIT3 _DBGTB.Bits.BIT3
#define DBGTB_BIT4 _DBGTB.Bits.BIT4
#define DBGTB_BIT5 _DBGTB.Bits.BIT5
#define DBGTB_BIT6 _DBGTB.Bits.BIT6
#define DBGTB_BIT7 _DBGTB.Bits.BIT7
#define DBGTB_BIT8 _DBGTB.Bits.BIT8
#define DBGTB_BIT9 _DBGTB.Bits.BIT9
#define DBGTB_BIT10 _DBGTB.Bits.BIT10
#define DBGTB_BIT11 _DBGTB.Bits.BIT11
#define DBGTB_BIT12 _DBGTB.Bits.BIT12
#define DBGTB_BIT13 _DBGTB.Bits.BIT13
#define DBGTB_BIT14 _DBGTB.Bits.BIT14
#define DBGTB_BIT15 _DBGTB.Bits.BIT15
