Is Wi-Fi Direct[p2p] Support in Android 7 ?
ThanarajS
Hi All,
  We want to know the Wi-Fi Direct Support is there or not in Android 7 Released BSP version 7.1.1_1.0.0?
  Can we get Wi-Fi Direct Supported BSP Source?
   Interfaces:
      As per android, Wi-Fi Direct will support with Normal Wi-Fi Mode only.
      If we want to enable wifi direct, wifi should be enabled then only we can use wifi direct.
      So is there separate interface is created for Wi-Fi[wlan0] & Wi-Fi Direct[p2p0] or It will work with one interface[wlan0] ?
Thanks in Advance!!!!
Regrads,
Raj.
Thanaraj Subramani
Labels (5)
aravinthkumarja
Senior Contributor II
Hi Raj,
Check Section 28 on the attached documet.
Aravinth
ThanarajS
Hi Aravinth,
   I didn't get any attachment in previous mail. Could you please send once?
Thanaraj.
Thanaraj Subramani
joanxie
The WiFI Direct is enabled by default in n7.1.1 release for BCM4339 WiFi chip. You can find it in Settings->WiFi->More.
aravinthkumarja
PFA.
