MPC5644A configuration problem when using hall angle sensor
nathan_
I have a problem when using MPC5644A.
I want to use the I/O port to receive the signal from the hall angle sensor, how to make the configuration
for the eMIO port of MPC5644A? May I get some examples of the configuration code?
petervlna
You can use eMIOS configuration from this project to sense signals:
Example MPC5646C eMIOS frequency measurement CW210
If you need more example on how to configure MCU, check this link:
https://community.nxp.com/docs/DOC-329623
Peter
nathan_
thank you very much, i will check these files and get some help.
