Hello All,
I'm using KDS v3.2.0 with a FRDM-KL25Z and I am only getting one build option: Debug.
How can I get the 'Run' option?
Solved! Go to Solution.
Hi Dan,
You can create new build configurations, see Build Configurations in Eclipse | MCU on Eclipse.
'Release' or 'Debug' really depends on your needs and settings, see Debug vs. Release? | MCU on Eclipse .
How to do 'Run', see Emulating Eclipse ‘Run’ with ‘Debug’ Configuration | MCU on Eclipse
I hope this helps,
Erich
Hi Dan,
I hope this helps,
Erich
Thanks Erich
These articles were exactly what I needed.
I guess I would classify myself as a 'printf()' debugger. While I have a degree in IT, I have never worked with other industry people, so haven't had the luxury of a mentor looking over my shoulder and saying things like "Why are you doing this the hard way?! Move over and let me show you how its done!"
I can use the debugger to single step and look at variable values but I get the feeling that if I understood how to use it properly, things would go a lot faster.
Is there a document like a tutorial on using all aspects of a debugger that you can recommend?
Thanks again
Dan
Hi Dan,
there are two different things:
Marek
Thanks Marek for your time,
I needed more information though. I have that now.
