I would like to use the ESAI interface on an SCM-iMX6Q as a general purpose 'frame sync' interface (i.e not for audio data), but I need to Tx and Rx 32 bits per frame, and I need all 32 bits (See attached document ESAI_RequiredTxRx.pdf, the Tx and Rx CLKs and FSs are generated by the external device).
Is this possible? From my reading of IMX6DQRM.pdf it looks like the ESAI can only extract 24 bits from within a 32 bit frame...is this correct or is there a way to Tx and Rx all 32 bits in the ESAI_ETDR and ESAI_ERDR?
Neil
Solved! Go to Solution.
Hi Neil
right, unfortunately ESAI can only extract 24 bits.
Hi Neil
