mbedtls- RSA 2048 Bit Key generation
Question asked by swaminathanrathinasabapathy-b44984 Employee on May 4, 2017
Latest reply on Mar 13, 2018 by vicentegomez
I had downloaded the KSDK for FRDM-K82, tested the mbedtls selftest code which is available in the below path.
SDK_2.2_FRDM-K82F\boards\frdmk82f\demo_apps\mbedtls\mbedtls_selftest.
Question: Required help to generate rsa_genkey -2048 bits
Downloaded the attached rsa_genkey.htm from mbedtls and integrated in selftest.c which is attached for your reference
unfortunately the code is going to Hardfault when executing the function memset.
Thanks & regards,
Swaminathan.R
Original Attachment has been moved to: selftest.c.zip
Original Attachment has been moved to: rsa_genkey.htm.zip
