Cannot find Qt5Widgets in qt with imx6 solox
gokhansahin
We're working on a project in Qt and using Sabre Solox kit. We're trying to configure the qt settings like this Setting up Qt Creator to build for i.MX6 . However, I didn't compile successfully a project, always get an error like the following image. You can see all setting in qtcreator options. Where do I mistake?
joanxie
what bsp version do you use? did you build the qt5 image successfully??
gokhansahin
I'm using L4.1.15_2.0.0-ga and build it successfully with qt image.
