RAM access protection in MPC5746R
kiranmuniraju
We need to ensure only particular software functions get the Read/Write permission into a block of RAM memory.As we looked into the reference manual, we think we have to use MPU or SMPU  modules to restrict access permissions.
I am new to SMPU module please help on this.If possible you can share some sample code snippets.
Thanks and Regards,
Kiran M
petervlna
Yes, you will use SMPU. All necessary details are described in reference manual.
Just give it some time it is not so hard to understand it.
Here is the application example.
Example MPC5748G SMPU initialization
https://community.nxp.com/docs/DOC-332545
Always check the community examples, this can save you time/
Peter
