u-boot: how to build mx6sxsabresd_spl_defconfig
andreasrebert
I tried to build SPL for mx6sxsabresd, but the build fails. Below you can see the steps I did and the error message. Is this build target supposed to work and if so am I missing something?
$ make mx6sxsabresd_spl_defconfig
$ make
LD spl/u-boot-spl
OBJCOPY spl/u-boot-spl-nodtb.bin
COPY spl/u-boot-spl.bin
CFG spl/u-boot-spl.cfg
CFGS arch/arm/imx-common/spl_sd.cfg.cfgtmp
MKIMAGE SPL
Error: Image corrupt DCD size 536870911 exceed maximum 220
arch/arm/imx-common/Makefile:73: recipe for target 'SPL' failed
make[1]: *** [SPL] Error 1
Makefile:963: recipe for target 'SPL' failed
Hi Andreas
nxp uboot does not support spl, community uboot supports it
GitHub - Freescale/u-boot-fslc: U-Boot tree to host pending fixes and improvements
uboot spl issues can be posted on uboot mail list
U-Boot Info Page
fabio_estevam
Hi Andreas,
mx6sxsabresd_spl_defconfig target builds fine with mainline U-boot. Just get the latest one from git.denx.de Git - u-boot.git/summary  and you will be able to build it.
andreasrebert
Hi Fabio and thanks for the suggestion. I've tested with both mainline and community u-boot and I can confirm that they compile.
Hi Andreas
U-Boot Info Page
