CW for MCU 10.6/10.6.4 SE (Eclipse) Licensing
sergiomadrigal
Hi NXP Technical Support
I am currently working with the FRDM-KL25Z hardware and I am going to use CW for MCU 10.6 SE (Eclipse) to programming. I would like to know, Does this license perpetual or only work for 30 evaluation days? and Does it enterprise or academy license? Is it the same way for CW for MCU 10.6.4 SE (Eclipse)?
Regards.
Sergio
stanish
Hi Sergio,
AFAIK there is no difference between v10.6 vs. 10.6.4 vs. v10.7 from licensing point of view.
Special Edition (SE) is a perpetual license which has some features limited (no C++, C limited,...)
Please check this document to compare Special Edition to the other versions:
http://www.nxp.com/assets/documents/data/en/fact-sheets/950-00437.pdf
Hope it helps.
Stan
sergiomadrigal
So, this does it mean that Is this free and enterprise license?
stanish
Yes, exactly.
S.
