Will KL03 Software/Watchdog reset & memory issue
tigerlo
   Will KL03 Software/Watchdog reset clear the internal RAM memory ?
   or Is there any document describe this ?
   Thanks.
Tiger
Hui_Ma
Hi Tiger,
The watchdog/software reset will let all module registers with reset value, that need to re-initialize all used module registers. The SRAM content only be affected by power, the watchdog/software reset doesn't clear the SRAM content.
Wish it helps.
Ma Hui
tigerlo
Hui_Ma,
   Got it, Thanks.
Tiger
tigerlo
Erich,
   thanks for your help, for one further question is that --
   As document said when watchdog/software reset it will clear some major function (such as RTC), but it is not very clear list what kind of major function, so after reset it is better initialize all H/W function & don't need de-initialize (before reset initialize driver)every H/W driver , is above description right ?
Thanks.
Tiger
Hui_Ma
Hi Tiger,
Wish it helps.
Ma Hui
BlackNight
Hi Tiger,
a watchdog does the same as a reset. So the watchdog itself does not clear the RAM, it would be the (C/C++) startup code which runs after reset.
I hope this helps,
Erich
