PRINTF with Keil uVision does not print negative numbers
bcstewart
I cannot get negative numbers to print out using KSDK 2.0.  I am using the accelerometer demo for the TWR-KL25Z48M.
All values are positive on the terminal.  But they show negative values in the debugger watch window.
I saw this post here:https://community.nxp.com/message/868842
But the fix is for KDS/Xpresso and not for Keil uVisoin V5.14.
Any suggestions?
Tags (2)
xiangjun_rong
Hi, Stewart,
As you see that the printf() function is dependent on compiler rather than SDK, can you ask Keil support directly? they can give professional answer i think.
Xiangjun Rong
