hiii
i am working on kl25z.
i am using kinetis design studio and KSDK 1.3.0.
In ksdk example code : host_msd_fatfs_bm_frdmkl25z running with no error.
when i import this code to my board and saw output in serial terminal it's show that
USB file system test
Waiting for USB mass storage to be attached...
so i can't understand what i do next?
hii Kan_Li,
i want to USB as a MSD means that whenever i connect my board to the PC and U disk is already attached with the board then in my PC Board is show like U Disk as a MSD and all data of U disk is shown there..
how can i achieve this type of configuration?
thanks in advance.
hii KAN_Li,
thanks for the reply.
i understand what you actually said , but i want ton rea and write some data through USB. is it possible in this example?
