CAN BUS communication k66f example
Question asked by alejandrosancho on Apr 27, 2017
Latest reply on May 11, 2017 by Alice_Yang
Dear all,
I am currently trying to set up a can bus communication using the frdm k66f. In the data sheet it says there are 2 can bus ports, on the other hand, there is no can protocol example provided and just the flexcan example is given.
The flexcan example as far as I understand provides a communication using 2 UART ports, but my goal is to send messages between both can ports (CAN 0 and CAN1) in the from k66f board.
Does someone have a short example where this is implemented or could somehow provide some insight into how could this be solved?
Thank you very much in advance for your time and help.
